Mounting Pre-09 Road King Classic Bags?
The Saddlebag Supports for the 2010 FLHX loop up in the back and include the back Zeus fitting for the hard bags. It loops up right where there is a protusion on the back of the Road King bags. The Zeus fittings won't line up with the Road King bags either no matter how I adjust the front bracket.
Eric
Eric
Thanks for the info, I looked at some 09 FLHX mounts on Ebay & it looks like the bar that runs up to the fastener must hit the molded part of the RKC bag. The only thing I can think of is to get the saddlebag mounts from a RKC or try to trim the leather bags. If it is the molded plastic on the back side of the bag you might be able to mark where it's hitting & use something to heat that portion & reshape it slightly. A heat gun & or a hot piece of tubing to indent that area, good luck. Hopefully some else may have an easier way, but most on here have gone the other way, wanting to have the security of locking bags.
I had the same problem with 2006 RoadKing Custom bags - trying to fit them to my '10 RK
rmwill
11-12-2006 11:49 PM
