Enabling ACRs in SEPST?
I installed my 120R a couple days ago and between killing the battery with the headlight before i can update the vcr and not finding how to enable the ACRs i'm not able to start it. Anyone know what the steps are to turn them on? I can see the disabled status in the map for it in the software.
Acrs
I have the file for the 120 in the bottom left hand corner of the screen. i have not loaded it into the bike yet because the battery died before i was able to complete the vci update. The damn headlights killed the battery during the update. Use to play around with the PCV but having a hell of a time with this SEPST. Suppose to snow tonight so i might just be putting the bike away till the spring. Wanted to at least try this engine. It says in the manual to make sure you Enable the ACRs before you change from the base map. Ive spent more time trying to get this software to work than the whole engine install. This is going to be a spring project i think.
aCRS
I got it figured out thanks. You have to drag things around to open them up. I thought that the acrs were not working because it seems to turn over harder than with the 96 so i pulled the fuse for them. They are working the engine will not even turn over without the ACRs . Engine seems to be way more powerful blip the throttle and it wants to throw the bike off the bike jack. hope the snow holds off so i can try it tomorrow Thanks
