Removing Caliper Bolts ....Ugh!
Old 11-23-2010, 08:15 PM
FDHOG's Avatar
FDHOG
FDHOG is offline
Originally Posted by Jinks
+1 That's what I do. Worked for me on primary cover.
Old 11-23-2010, 08:19 PM
Mathews2's Avatar
Mathews2
Mathews2 is offline
+2 same here, they are money well spent
Old 11-24-2010, 12:03 AM
bagman1's Avatar
bagman1
bagman1 is offline
theres a big difference on using a hand impact wrench on a 1/4" cover bolt and a 10 mm bolt torqued to 20+ lbs.
Old 11-26-2010, 07:01 PM
jzgbx2's Avatar
jzgbx2
jzgbx2 is offline
3rd Gear
Thumbs up
Finaly got em off tonight! Found the primary problem was a socket that didn't allow full engagemant ofer the bolt head as the socket wasn't deep enough. Saw the problem after it was too late on the right side. I had another socket set that had was deeper ( but not a deep well as all mine DWs were 6 pt) and the left side came off like all of you said, with a little tap on the drive. So even as the left came off ok the right was still a problem. Got the fender off and pulled the right side pads out of the caliper to free things up a bit. Next it was torch heat and vice grips.....no turning back now. They would not budge but it was impossible to generate any torque with V grips as the spun, grinding the bolt head into mush. Someone recommended a Sears bolt removal set. Figured I had nothing to loose so invested another $30 into the cause and they worked great. Had to hammer the right size on the bolt but as soon as it was installed I could tell it was snugged up tight and holding torque. Could use a 1/2 drive and a hammer strike and thank you sweet Jesus they broke loose. Goobered up the bolts but new bolts are a small price to pay after investing $50 in the process. Sucessfully getting 'em off ....priceless. Time for a celebration beer ....or 6. Thanks for all the great advise ....thought I'd pass along my learnings.
handirifle
06-08-2019 11:28 PM
c50plus
01-29-2010 11:09 PM
stevec314
04-18-2008 10:22 AM
michaelbarry
08-31-2007 04:40 PM
StreetGlide2006
12-27-2006 08:33 PM
Quick Reply: Removing Caliper Bolts ....Ugh!
