Clutch cable comes loose
If it's screwing in and backing back out over time, you may just need a little blue locktite on the threads. If the cable casing is coming out of the cover and everything is right on the inside, that should remove any slack at the clutch lever, not add slack.
If you are saying the cable disconnects from the ball and ramp lever, you may have to double check to make sure that the clutch is adjusted correctly. If the clutch is right, you may have to remove the cover and make sure the snap ring is in place and the lever is in the correct position. If that's right, the ball and ramp mechanism may be worn out.
A loose lock nut on the cable adjuster could cause this as well.
There are some very kowledgable folks on here that will likely have other suggestions.
00glider
05-20-2006 11:58 PM
