hooking up a battery tender
So i bought a 09 streetglide with all the bells and whistles. When it got cold and i couldn't ride her very much i want to hook up my battery tender with the leads you leave on the battery but i'm thinking i shouldn't just unhook the battery with the security system. so i found a little 9 volt little battery with a cigarette lighter attachment for cars (so you won't loose any memory and security stuff) but its for cars when you unhook the battery . so my question is would you trust this little gismo or just use the alligator clips and ask the dealer to put the leads on at my next oil change next summer
There's no need to worry about the security system.
As others have said, it's a simple job to remove the battery cables and attach the pigtails for the battery maintainer. Once you have it connected, route it out under the seat somewhere and secure it where you can access it without removing the seat. Put everything back together, park the bike where you want it, and connect the battery maintainer and plug it in.
