Compensator replaced under warranty??????
Old 12-18-2010, 07:48 PM
Gliden's Avatar
Gliden
Gliden is offline
Anyone have a service b on this?
thanks
  #32
Old 04-05-2011, 06:37 AM
mdtpr's Avatar
mdtpr
mdtpr is offline
Mine is at the Harley Shop as we speak for the dreaded starter banging noise. They seemed oblivious to this so called "compensator issue". They never heard of anyone having issues with the compensator. They asked me if my battery was good and if I might be letting off the starter button while cranking causing the noise. Of course he turned the motor over several times while I was there and it started right up every time. Mine is out of warranty so I am bracing for the worst$$$$$$$$$$$$
2008 Anniversary Ultra Stock Motor
  #33
Old 04-25-2011, 05:23 PM
mdtpr's Avatar
mdtpr
mdtpr is offline
Default Update
Just got mine back from the harley shop. The compensator bolt was loose so they replaced the assembly with the Screaming Eagle Compensator. They also covered everything under "good will" even though it was out of warranty!!! Makes a big difference with the upgrade.
  #34
Old 04-25-2011, 05:45 PM
Stiggy's Avatar
Stiggy
Stiggy is offline
Received 5,825 Likes on 3,176 Posts
My now "old" 2000 FLTRSEI has had no problems with anything in the primary and just passed 87,000 miles this past weekend, Guess I'm not really up on some of the new technology.
What did HD do to weaken what was a bulletproof compensator unit?
  #35
Old 04-25-2011, 09:00 PM
sportyrider1's Avatar
sportyrider1
sportyrider1 is offline
Mine was changed at no cost, had to go to 2 diffrent dealers before I got it done. first dealer was 1 of the suppose to sound like that shops 2nd did it just on my complaint of the bang at start up.
  #36
Old 04-26-2011, 06:14 AM
azmachinist's Avatar
azmachinist
azmachinist is offline
Just had mine replaced under the ESP. Along with the starter, rotor, primary chain & clutch bearing. Had them upgrade to the SE compensator. I was told the bang at startup was normal too. The hard starting when it was hot was the only other symptoms I had. No abnormal noise in the primary. The bill was $1577.00. I usually don't buy extended warranties. But i am glad I had it this time. Cost me $203 out of pocket to upgrade to the SE and the $50 deductible.
  #37
Old 04-26-2011, 06:43 AM
Rascal4546's Avatar
Rascal4546
Rascal4546 is offline
6th Gear
Has this issue been reported on the 07 model? I have an 07 that I get this noise from occasionally when starting.
  #38
Old 04-26-2011, 11:42 AM
Big Daddy FLHX's Avatar
Big Daddy FLHX
Big Daddy FLHX is offline
Default Dc area
Anyone have a dealer in the dc metro area that did not look at them like they had two headed when they went to the service department with the compensator bang????????
  #39
Old 04-26-2011, 06:02 PM
jrike's Avatar
jrike
jrike is offline
any recomendations for a reputable dealer in or around boston that has done this under warranty.im due for my 10,000 mile service and would love to get it done while its there.without paying of course.
  #40
Old 04-26-2011, 06:19 PM
ybnorml's Avatar
ybnorml
ybnorml is offline
Received 29,086 Likes on 11,627 Posts
" compensator replaced under warranty ?"....I missed out on that one by 5 months.
Mine started banging and clanging on start-up last Oct....5 months
after warranty ended. Dealer couldn't / wouldn't help me out....
Indy just replaced stock with SE upgrade 2 weeks ago....seems to work as
advertised, no more clang and bang on start-up.
Quick Reply: Compensator replaced under warranty??????
