what size of cam
Old 11-21-2010 | 07:58 AM
clucker's Avatar
clucker
Default what size of cam
i have an 05 standard,88 cube,i already did the race tuner,hi flow filter and true duals but now would like to have a little more than just about everybody else.by changing the cams i'm hoping to get a better sound plus the extra power,anyone have any ideas on who and what size cam i might need,thanks
Old 11-21-2010 | 08:20 AM
Bodean46's Avatar
Bodean46
I went with the S&S 510G's in mine. Like yours the rest of the motor is pretty much stock except for the Fueling oil pump and cam plate and the K&P Engineering oil filter. Dyno'd at Doc's in St Louis and am well pleased with the way it runs. I've outrun a lot of 96" stock motors and a few 103's.
Old 11-21-2010 | 04:05 PM
rags's Avatar
rags
I am happy with the Andrews 21N cams I have in my 88".
Old 11-21-2010 | 04:29 PM
clucker's Avatar
clucker
Default much difference
did it make much difference in your bike,i figure it will probably cost 600 or so i wanna make sure it's worth it,thanks
Old 11-21-2010 | 06:31 PM
rags's Avatar
rags
If it had not been for having to address the tensioner issue I wouldn't have changed the cams. But, since the tensioners were going to have to be changed sooner or later I decided to go with the conversion kit and thought the 21N cams would work for me. Bottom line is yes, made a big difference in the bike and worth the money to me.
CR3999
2014-2023 Touring Models
02-23-2016 04:52 PM
springer 03
07-16-2014 09:55 PM
MichiganRider
12-31-2011 03:47 AM
harleynt
Exhaust System Topics
09-11-2008 07:54 PM
BadX
10-04-2006 03:41 PM
Quick Reply: what size of cam
