Almost lost my shifter today
I put about 100 miles today running a couple of places and errands. Everything was fine till I was getting off the hwy to go home. Went to shift down on the exit ramp and to my surprise, I had no shifter. I pulled off to the side at the bottom of the ramp and looked down. The shift lever was sitting down along the floorboard. Fortunately I was less than a mile from home so I grabbed the shift linkage by hand and put it down in first gear then limped the rest of the way home. Once I got home an took a look I found the shifter shaft had disconnected from the inner lever next to the cylinders. I thought the bolt must have come loose and fell out but when I looked it was still there and still torqued down tight. I took the bolt out and took a good look at it and the shaft. Apparently, the threads in the bolt lined up with the groves in the shaft. Over time the shaft wore a flat spot on the bolt and finally worked it's way out of the lever. I was going to just get a replacement bolt but the grooved in the shaft are worn also so I think I'll just replace the shaft. At least the shift lever didn't fall off completely.
I was traveling up I-5 on my 07 SG and went to shift up and no heel shift. I pulled out the allen wrench and moved the toe shifter up. I went to the dealer and told them the problem and they replaced it. I installed the new heel shifter and off that one went to. So I replaced them with after market shifters and decided to keep the toe shifter elevated just in case. Well it has been 2 years and I have not lost the after market shifters.
Take my advice and get this shaft as a replacement. Well worth the money and it will solve any future issues with the front shifter shaft seizing up in the bore. Might as well get it if you're going to replace the shaft anyway.
I've had this part on my past 2 bikes and it is a very nicely made part. Be sure to use grade 8 bolts on the levers and blue locktite them in with the proper torque and you will have zero issues in the future.
Greasable shaft
Greasable shaft
I figured I might not be clear in my description. The shaft wore on the inside connection where the lever connects to the shift linkage not the outside where the front and rear shift levers attach.
Greasable shaft
Greasable shaft
If you get one, let us all know what you think of it.
I thought about the drilling/zerk fitting option. I have no problem drilling but I don't happen to own a tap and die set to thread the hole for the zerk fitting. I priced the HD shaft online last night and it's only about $20. For that big of a cost difference, I'm thinking a good coat of anti-sieze, some annual maintenance, and I'll be good to go.
