rpm at idle
Old 11-20-2010 | 10:08 AM
frankiefire702's Avatar
frankiefire702
Default rpm at idle
Quick and dumb question. What's the normal idle rpm? I changed the exhaust on my bike and it seems to be idling high.
Old 11-20-2010 | 10:09 AM
fireaxxe's Avatar
fireaxxe
Should bounce back and forth between 990rpm and 1005rpm. I have mine lowered a bit 976rpm but around 1000rpm is normal.
Old 11-20-2010 | 10:16 AM
Donnylee's Avatar
Donnylee
About the same on my 2008.
Old 11-20-2010 | 10:49 AM
twistedcherokee's Avatar
twistedcherokee
Mine is a 1999 & I have mine set at around 700-800. Cooled @ the stop lights & less vibration. I rode my wifes cousins 08 UC & it was around 1000 & if it were mine I would lower it too. I have had the bike for over 3 years now & 30000+ miles (had less than 50000 miles when I got ot & has 83000 now) has the same battery & I don't use a battery tender.
Toby
Old 11-20-2010 | 10:53 AM
1flhtk4me's Avatar
1flhtk4me
My '06 Road Glide was at 1000 just like my new Limited.
Old 11-20-2010 | 11:03 AM
PistonPuller's Avatar
PistonPuller
Its based of engine temps. Starts at 1400 @zero temps, then around 80 degrees it drops to 1k and hovers there.
Old 11-20-2010 | 11:16 AM
frankiefire702
Thanks guys. Mines around 1000. I guess its normal. Seemed kinda high too me.
Old 11-20-2010 | 11:32 AM
Pine Tree's Avatar
Pine Tree
MODERATOR
Veteran: Marine Corp
Assuming it's a late model TC, the idle speed (as suggested above to be around 1000 rpm when warmed) is set at that speed for oil pressure purposes.
Much lower then you'll start to see the oil pressure at idle drop to near zero...not a good thing.
Old 11-20-2010 | 11:56 AM
maryvillept's Avatar
maryvillept
sounds better at a lower idle, but it can damage the engine
Old 11-20-2010 | 12:04 PM
carrotzilla's Avatar
carrotzilla
SG @ 1K w/V&H slip on. All my jap bikes were about the same before and after can swap.
Quick Reply: rpm at idle
