Any 2011 owners notice the way........
The compression release unloads the cylinder pressure to allow an easier start. The moco saves money and can use starters that provide less torque. I have read that the newer bikes unload the rear cylinder when at idle to help with the overheating and new EPA regs. That's what I believe anyway.
Rear cylinder shutdown........Only if you set it to do that. The default setting is to leave both cylinders on at all times. Which is the way I have mine set. If I get stuck in traffic during the summer, I'll switch it on. Takes 2 seconds.
Mine starts immediately, stock pipes have the low throaty rumble (without waking the neighbors when it starts up), but hit the hammer and the exhaust really roars.
Love it!
You rotate the throttle forward and hold it for a couple seconds when in neutral idle, it'll activate it and you'll feel the rear cylinder stop firing.
My 11 with the 103 cranks over kinda slow too, I understand the complaint. It always starts fine but it cranks slower than I expected, especially compared to the other non-Harleys I've owned.
I'm sure some of it is related to the starter spinning the primary chain over instead of just the engine itself. That's a lot of mass for the electric motor to turn.
Also 1 of 3 conditions must be met for the rear cylinder to stay off
Clutch lever pulled in
Trans in neutral
Throttle less than x %
Any of those 3 prevent you from taking off on one hole
I actually used the rear cyl cutoff and it is very transparent. Plus it makes it lope like it's 69 Chevelle, GRIN!
This is what Harley says...
Automatic Compression Release:
Automatic Compression Release (ACR) valves reduce the strain of starting your high performance motor by reducing cylinder compression - automatically! The engine is easier to turn over resulting in less wear on your starter and battery. After start, the ACR valves close to restore full compression. ACR give you peace of mind and protects your investment. ACR can be installed on stock or Screamin' EagleŽ Performance cylinder heads for all '07-later Twin Cam equipped models. Install requires machining to be performed by a competent machinisht using the Screamin' EagleŽ Automatic Compression Release Fixture Kit P/N 94648-08 (sold separately). Installation requires separate purchase of model specific ACR Wiring Harness P/N 70623-06 or 70623-08.
28861-07A
Fits '07-later Twin Cam equipped models. Can be used with Original Equipment or Screamin' EagleŽ Cylinder Heads. (each)
28861-07A
