Any 2011 owners notice the way........
11-18-2010, 07:36 PM
Quote:
Originally Posted by
FLoTR
the 11's have compression releases? why?
Only the 2011's with factory 103" motors and larger have ACR's.
They are internal, you can't see them.
11-18-2010, 07:39 PM
Quote:
2011 FLHTK 103 sure sounds lame when starting.
Reminds me of an 80 model Dodge. Whats up with that?
I believe the new 103s have a higher compression ratio than the 110s. That's why they come with ACRs.
Someone even more informed than me can confirm that, I'm sure.
11-18-2010, 08:00 PM
FDHOG
The 2010 limiteds with 103s also have ACRs
11-18-2010, 08:53 PM
So, only factory 103's have the ACR's. That would explain why my buddys dealer installed 2010 103 sounds normal. Thanks for the info
11-18-2010, 08:59 PM
bmaier
I know, but he was asking about the 2011's.
11-19-2010, 12:15 PM
Put you a hot cam in it, you'll notice the difference!
11-19-2010, 02:56 PM
Guess now that I know about the ACR its just normal. Thinking about it, it does sound like an engine cranking with no compression for just a split second and the it cranks up.
Good thing is shouldn't be anymore grind like I had with my 08
11-19-2010, 03:26 PM
sifularson
Thanks for the info, I learned something today
11-19-2010, 04:06 PM
FLoTR
The compression release unloads the cylinder pressure to allow an easier start. The moco saves money and can use starters that provide less torque. I have read that the newer bikes unload the rear cylinder when at idle to help with the overheating and new EPA regs. That's what I believe anyway.
11-19-2010, 04:10 PM
sifularson
Yes, the 110s only have 9.15:1 CR
