Single front brake line for street glide
Old 11-17-2010 | 01:46 AM
Russbucket's Avatar
Russbucket
Default Single front brake line for street glide
I'm having trouble finding a stainless brake line for a street glide. Just running a left side only brake and stock 10mm banjo fittings and orientation will work. I'm assuming someone has been down this road before and can help. I have searched but haven't really found anything.
Thank you and I appreciate your input.
Old 11-17-2010 | 02:14 AM
slothy's Avatar
slothy
call up http://www.spieglerusa.com/
you might have to measure, but they can make you any line and usally ships that day.
Old 11-17-2010 | 09:11 AM
steveh326's Avatar
steveh326
J&P Cycles sells goodridge brake line components where you buy the 2 banjo fittings and the correct length hose to connect them. I've used this setup on 3 different bikes and they work great. just be sure you get the brake hose that is clearcoated. they have one that is raw braided steel and I got it by mistake one time... but was able to exchange it np.
Old 11-17-2010 | 09:39 AM
Russbucket's Avatar
Russbucket
thanks gents. that will work
Hey Steve, what length did you use?
Old 11-18-2010 | 12:03 AM
SupaDave's Avatar
SupaDave
I just did the same thing... I used a piece of speaker wire, to run the route that the brake line would go. Measure it out and there ya' go! I put 13" Cyclesmiths on and used a 47" universal brake line. Just bought the screw on line fittings.
http://www.motorcycle-superstore.com...T.ac=SLIsearch
LN2_Casey
Harley-Davidson Street
05-18-2018 02:08 PM
KDUBYA
05-20-2014 11:45 PM
perpulreaper
EVO
07-20-2009 10:00 AM
HarleyArcher
02-20-2008 08:16 AM
jammer1
08-02-2006 10:28 PM
