Tips on installation of PC111
Well guys, you finally talked me into ordering one from fuelmoto. I was just wondering if there were any installation tips on a RD King for the PC. I have read that some guys have fried their PC111,s by getting them wet. Are there any added installation tricks to help avoid such problems? Eg: wrapping electrical tape around connectors after installation. Any help will be apprieciated, you guys have been great. Thanx
RE: Tips on installation of PC111
Not sure how getting wet would hurt it?, but I used dilectric grease on the connectors and I did not mount up inside the bike as the instructions say, I found it will fit perfect on top of the ecm, just use the zip ties it comes with to mount it. It tucks in perfect and makes it easy to make changes without pulling it all out again, cover fits right over with no problem.
I just got mine last night. I have it at work today (new toy). I have it running on a 9V battery for power. I just loaded the map for my bike M807-005. What happens if I pull the battery off before installing, or do I need to keep battery on until I have all the cables plugged in to keep the map loaded?
06 Ultra
SE Pro One Slip Ons
SE Air Fiter
Stage 1 Flash
Thanks
06 Ultra
SE Pro One Slip Ons
SE Air Fiter
Stage 1 Flash
Thanks
I installed mine the same way gunrunner did. I tried the spot Dynojet recommended but it kept falling down as the velcro wouldn't stick not to mention that it puts it in a place more prone to getting wet. I attached it to the ecm underneath the side cover also.
ORIGINAL: gunrunner
tip for installation-have zip ties on hand-they are the best way of fastening the PCIII. I tried it the PC III instruction manual way and ended up just zip tying it to the ecm instead. Its been over a year and it works fine.
Dforeid- Yes and no. Yes you can just unplug it and your stock ecm will now operate normally. If you have only the PCIII and new pipes with stock air breather you will be fine. However, if you have a new air breather also (as most of us with PC IIIs do) the stock ecm will work fine, BUT, your bike will now run very lean due to all the air it is getting from the new air breather and could possibly damage your engine. So it is a judgement call as to weather or not you want to run it like that.
I always have a roll of electrical tape in the saddlebag anyway so I figure if the PCIII ever goes down I would pull it and then wrap the K&N with some tape . . .basically choking some of the air from the bike by lowering the volume of air going into the intake. Obviously not covering the entire filter just 1/3 or so. What do you guys think?
