Oil Cooler or Temp Gauge?
#41
#42
What I was trying to say is if we are inching along the EITMS does not come on because we never stop long enough. Takes like a minute for it to engage or something after you've stopped right? Won't come on if you're moving.
lp
#43
No, ours is the same as yours. If the oil temp is 230+ our bikes go straight into EITMS mode if we are stopped. I have actually had it come on lower like at 210...just depends.
lp
lp
If I stop, it takes something like a minute to kick in, you're right.
#44
I would put the oil cooler on and, if you like looking at something you have no control over, put the oil temp gauge in later. The cooler actually reduces the engine temps whereas the gauge just causes your body temp to climb because you can't do much more about the engine temp given what you have already done with the cooler IMHO.
#45
I considered both essential when I bought my bike, and they were the first accessories I installed. If I had to make a choice between one or the other I would opt for the cooler, but would add the gauge sooner rather than later. I'm a believer in coolers for TC engines and I also like information. Oil temperature is critical info IMO, and I want to know what it is at all times. I use it more than any other gauge except the tach and speedo.
OTOH if you ride in winter like we do in S. LA you could probably do without the cooler 'til spring, so a fair argument could be made to install the gauge first. I wouldn't advise running a TC engine in the kind of heat we have here without a cooler, or anywhere else in the continental U.S. in summer.
#46
Regarding the relationship between EITMS and engine temperatures, the point at which heat-management kicks in is related only to front head temperature, usually 285-290° depending on year-model. Oil temperature could be 150°, 300°, or anything in between when EITMS activates, as the temperature fluctuations at the head are much faster than the oil measured in the pan.
For those of you with a PCV and are connected to the J1850 port on the ECM, connect the PCV to your laptop, start the bike cold, and then watch how fast the engine-temp reading climbs when the bike is stationary. The head will heat up fast while the oil will be much slower. The oil also cools down much slower than head temp, so you could conceivably have 300° oil in the pan and be below the threshold for EITMS to activate.
2010, aftermarket, bud, classic, cooler, coolers, custom, davidson, gauge, harley, jes, jescustomaccents, oil, temperature, ultra
