Rear Wheel Off Center 3/16".. 2009 Streetglide
Did I read right that you were using the rotors to check alignment?
The hubs are not the same width Front and Rear.
Your wheels.tires are not the same width front and rear are they?
Not sure what front ends you are using, but the ones with which I am familiar do not has same size spacers on both sides.
Most have a stepped axle.
Im measuring alignment of the tires by using the sides of the rear tires and the front rotors. If the front tire is centered and the rotors are equal distance from the center of the rim they are perfect for this.
I don't expect them to line up perfect I expect any visible gaps to be equal on both sides. That will tell me if the line of my fry and rear tires are the same.
Even if you are cutting spacers on a lathe, most front ends use a stepped axle and not equal length spacers, but I probably don't have the chopper experience you do.
Sounds like you are measuring correctly, thanks for that explanation. I believe the rear tire is likely offset, the motor company has offset the rear tire since the beginning of time. I am not home to go out and check my FLHT or I would do it just for posterity.
This is a good question, I hope it gets resolved, please keep us updated.
The spacers on pre 08 bikes are different thickness side to side, 08 & later are the same, that's why when putting late model wheels on an earlier bike you need to use the late model axle & spacers, or make up your own. Does your bike pull to the left or right when you take your hands off the bars at highway speeds?
Yes I have to keep a little pressure on the bars all the time at hwy speeds or else it drifts to one side.
Appreciate all the feedback by the way!
I think the answer is going to end up that it was designed that way but Im hoping not cause I can feel it.
I've complained to the dealer and they always said its normal. I didnt have a straight edge long enough to measure it myself until recently.
Received 75,081 Likes
It actually turns differently right and left. One way its more of a roll and the other its more of a sharp pull. If youve ever had a rear tire out of alignment, twisted in the swingarm, you will know what I mean.
Check the alignment on the rear wheel, there's enough slop in those adjuster cams to have the rear tire off slightly, that's about the only way that the alignment can be off other than the frame being out of whack. The right side cam isn't a real tight fit against the flat on the axle, meaning the right side could be slightly further forward. I change my own tires & I always check this, it only takes a 32nd to give you pull. That said the crown in the road will also give you a slight pull, I always check on both lanes of a 4 lane to see if the pull is still there, even more weight in one saddlebag than the other can cause a pull, just throwing this all out there. hope you solve your problem, good luck.
