Ultra TP light kit part# confusion... HELP!
I want to add the "Ultra" tail light kit to my "Classic" tour pak. I've found 2 kits that Harley offers, #68012-88E, fits 88-05 and #68172-06, fits 06 & later king tour paks. My bike is an 07 but, I bought the tour pak used & don't know what year it is. Is the difference in part #'s the size/shape of the tour or in the wiring plug ins? Hard to tell in the attached pics but, the tour pak does not have the molded contour (??) on the sides & back. Also, is this kit plug & play... is there a plug under the seat or something to just plug it into?
Thanks for any help,
Dave
Dave
You can check the parts on the Ultra tour paks 2005 v. 2006 and newer using this website:
http://www.shopronniesharleydavidson...idsonparts.htm
The tour pak wiring harness is a three-wire black connector along the antenna cable (under the seat/left side frame rail/under left side cover). It should have ane black wire, blue wire, and red/orange (?) wire IIRC.
If you buy the kit, be sure it comes with the template necessary to cut the corners and drill mounting holes.
FWIW, I'd have it painted to match the tour pak color; similar to a painted inner fairing as a cosmetic improvement for modest cost.
Carl
Carl
