Starting and Shifting - What's "Normal"?
Greetings,
I've never owned a Harley until my recent acquisition of a 2008 Road King, so I'm not sure what is "normal," and what isn't. I've only had time to ride the bike a few times, for short distances. It's currently got around 13.5K on the clock.
I'm trying to determine if some of the things I'm experiencing are normal. For example, when I start the bike, there's a loud bang associated with it, almost like a gunshot. When I put the bike in gear, it "clunks," and also "clunks" when shifting through gears.
The dry clutch on my Ducati's made a racket, but that's the way it was designed, and you get used to it. I just want to be certain what I'm experiencing is also part of the Harley "experience," before I get to breaking something expensive.
Thanks!
Thanks!
Thanks everyone. The "bang" is definitely not a backfire, as it's mechanical in nature, and related to the starter in some way. Is the gear on the starter retracting supposed to make that loud a noise?
Regarding the clutch, even though my Ducati clutch made a racket, the bike shifted into gear like butter. I guess I'll just have to get used to "cracking" into gear with the Road King.
I have to say, transitioning from a sport bike to the Road King has been easier than I thought. I just wish the foot boards were more forward. I feel like I'm sitting in a chair when riding it.
The clunk (especially from neutral to first) is largely a function of clutch adjustment and the type of fluid used. I had good results using Formula+ and I've been on automotive Type F ATF in the primary for quite some time now. No noise at all shifting from neutral to first and the rest of the gears are relatively quiet as well.
Some fluids used in the primary seem to cause the clutch plates to stick together more than others. That's been my experience at least....
As blusmbl said that start-up BANG! you're hearing comes from the compensator sprocket. Very annoying (I'd like to crotch kick the HD engineer responsible for that one but I imagine I'd be at the end of a long line). Twin Cam tranny's are the "clunkiest" compared to anything previous - my Evo shifts buttery smooth in comparison. Look to the SE compensator that dawg refers to for relief from that obnoxious banging.
