Anyone having trouble with HD backrest?
Mines not that far back but i have to ask, how do you fit in the seat if the backrest is going to be that far back? If your that tall you might want to look at the tall boy seats? I think the back rest is made to work with all the seats but only at certain positions for certain seats, ie I don't think it will work with a reach seat and trying to put the rest to far back or a tall boy seat and trying to put it on the closest setting.
xd, I had the same problem. The backrest just seem to push me too far forward and could not get it to work in the last hole with the sundowner. Eventually I sold the seat and backrest and went with a Mustang. I got the super tourning seat. It's large, but the back rest is adjustable a bit, but sits me back far enough that I'm comfortable.
That's a common complaint with the HD backrest. You can bend the bracket or put some washers under the mount. Best bet is to get the Mustang.
Unfortunatly the HD backrests are mostly onesize fits all. Take it to a welder and have them cut about 3/4" out of the middle of the support bar off and then reweld. This will help it set the backrest lower on your back and not expose so much of the suppost tab while its on your bike. You can also have the welder heat and bend the support tab back a little to fit the lean angle you need. Ive alway liked my backrest as low as they will go against the seat to give my lower the most support.
