Another way to fix broken fairing brackets
Old 11-05-2010, 09:02 PM
fabrik8r's Avatar
fabrik8r
fabrik8r is offline
Default Another way to fix broken fairing brackets
After two go rounds with repairing and replacing brackets I wanted to do something that would truely be a permenant fix. I made this fairing support bracket from a piece of 3/4 aluminium angle. It spans all the way across the fairing from mirror mounts to top speaker screw to main vertical mounts, it ties everything together nice and firm. This was a very slow project with a lot of trial and error, and hand fitting and adjusting every bend. In conjunction with the factory failure prone brackets, its hell for stout, you could probably lift the front end by it. I didn't have a welder but it still came out pretty nice with the trusty rivet method. could have made it lighter and neater with a welder. Anyway, I think I'm done repairing fairing brackets. I highly recommend building yourself one of these. Good winter project.
Attached Thumbnails Another way to fix broken fairing brackets-100_0712.jpg   Another way to fix broken fairing brackets-100_0713.jpg   Another way to fix broken fairing brackets-100_0714.jpg   Another way to fix broken fairing brackets-100_0715.jpg
Old 11-05-2010, 09:05 PM
nvsteve's Avatar
nvsteve
nvsteve is offline
Holy Moses. That'll work.
Old 11-05-2010, 09:13 PM
Iceman24's Avatar
Iceman24
Iceman24 is offline
Received 2,250 Likes on 1,641 Posts
Looks like it will work - that's alot of alum & rivets. Might want to patent before HD steals it away.
Old 11-05-2010, 09:46 PM
Streetrunner's Avatar
Streetrunner
Streetrunner is offline
I have used just the angle brackets, so far so good. Your brackets look really solid, should last a long time.
Old 11-05-2010, 09:53 PM
DrPlastic's Avatar
DrPlastic
DrPlastic is offline
Crap for what you paid for all that mass up high in the fairing you coulda bought the HD new and improved models that came out last year!
Old 11-05-2010, 09:57 PM
jasnusc's Avatar
jasnusc
jasnusc is offline
How far back was it breaking? Im amazed all that is necessary.
i actually braced mine with two little L brackets before they broke just to try to prevent it.
Old 11-05-2010, 10:16 PM
Jim Dawson's Avatar
Jim Dawson
Jim Dawson is offline
A bit of over kill maybe? Alcoa must be very happy.
Old 11-05-2010, 11:47 PM
Harleypingman's Avatar
Harleypingman
Harleypingman is offline
Top marks to you for your fabrication skills.
Since repairing a broken fairing (black) bracket with an inexpensive L bracket at the top many miles ago, I haven't had a black/vertical bracket or speaker/horizontal bracket break.
Again, really nice fabrication; thanks for sharing.
Wonder if anyone will ask you to make one for them.
Carl
Old 11-06-2010, 05:01 AM
William The Red's Avatar
William The Red
William The Red is offline
Good job it is ez to see you put sometime in on it. A friend had is break I program water jets so this winter I will pick up the pattern off my 2010 and fit it to is. GOOD JOB
Old 11-06-2010, 05:34 AM
Pine Tree's Avatar
Pine Tree
Pine Tree is offline
MODERATOR
Received 1,964 Likes on 463 Posts
The brackets were designed to break before the fairing does...it might prove to be more cost effective just to change a bracket once in a while instead of a fairing.
Good luck!
Quick Reply: Another way to fix broken fairing brackets
