Went to the Darkside(car tire)today
Old 12-26-2011, 07:40 AM
coolerman69's Avatar
coolerman69
coolerman69 is offline
Originally Posted by katobird
I'm very interested in the CT.
Coolerman and Quad...I'm watching this very close..
I'm scared it won't fit Austone 175..
I like my stock look
But After alot of reading some fit some don't..
Yes I am buying my own tire changer too..
It fits on my 06
  #632
Old 12-26-2011, 08:20 AM
Dave2261's Avatar
Dave2261
Dave2261 is offline
Interesting
  #633
Old 01-04-2012, 07:04 PM
jmunsey's Avatar
jmunsey
jmunsey is offline
5th Gear
Anyone know of a car tire that will go on a 2007 FLHPI Police Road King. It currently has a Dunlop D402 on the rear. Before the negative comments.....I do not care how it corners. I have a double wide 2 seater sidecar and it does not lean. Current Mcycle tires last about 4k due to the additional wear of the sidecar. A car tire may work out ideal for this application.
The D402 has listed on the side MU85B16 M/C 77H
Much thanks for input.
Jim
L.A. (Lower Alabama!!)
  #634
Old 01-04-2012, 07:09 PM
Quadancer's Avatar
Quadancer
Quadancer is offline
Katobird- no need to watch ME, because my Vredestein is only at about 16k and has a fair amount of tread left, so maybe early summer I'll have it worn enough to justify an Austone.
  #635
Old 01-04-2012, 08:16 PM
coolerman69
Jim
Austone 175r16 should fit fine. RKs and EGs have the same rear end I'm pretty sure.
  #636
Old 01-05-2012, 06:47 AM
katobird's Avatar
katobird
katobird is offline
I finally did some measurements...
With the Dunlop 402 I only have about 1/4" on the left side....
So all bets off I can't (don't) want to take the chance of it not fitting..
IF I find a 165 or 155 in the future...IT'S GOING ON
Good luck guys
  #637
Old 01-05-2012, 07:06 AM
coolerman69
With the Dunlop 402 I only have about 1/" on the left side....
Good luck guys
It'll fit. Another member here used one on his 07 and left the belt guard on. 07s must be a little different than my 06.
  #638
Old 01-05-2012, 07:31 AM
katobird's Avatar
katobird
katobird is offline
It must be..
I beleive it was you who gave me a measurement of 6 3/8" for the Austone tire..
1/4" clearance on mine with the D402 at 5 3/4" wide..
I'm a little bummed out.
The L/H fender is closer than the right side about 3/8" and the taillight end
The belt guard is the 1/4", but I prefer to leave it on and I looked at a few options on modifying it....but just won't cut it..
Thx cooler
  #639
Old 01-05-2012, 08:24 AM
Quadancer's Avatar
Quadancer
Looks like 5/16" plus a millimeter for clearance is all you'd need. Grinding a very small crescent out of the guard won't be noticable, ESPECIALLY since you have saddlebags. Also, IF you had fender contact, bulging it out slightly would be also hidden.
I'd do it in a minnit. I'd either grind and paint the edge on the guard or just bend the bracket to move it over a hair. It wouldn't be much, according to your numbers.
Some of the metric guys have modified their frames, dented the heck out of their driveshaft tubes, and all kinds of crap because they just won't put a narrower (and I think better handling) tire in there.
Your mods would be very minimal.
  #640
Old 01-05-2012, 08:33 AM
mrnone's Avatar
mrnone
mrnone is offline
FLD dyna switchback is a 17 inch rim with 4.5 inch width.
any suggestions? my back tire is about done.
thanx in advance
looking forward to riding on the darkside
Quick Reply: Went to the Darkside(car tire)today
