Went to the Darkside(car tire)today
#372
#373
So that's a 130/90/16. I think you are out of luck but check here....
http://darkside.nwff.info/
Do a LOT of reading on all the forums!
#374
Roberto, in the thread you quoted from,(https://www.hdforums.com/forum/touring-models/650365-does-anyone-know-how-much-a-dunlop-180-65b16-weighs.html) there were two other forum members that posted the weight as only being 14 lbs apiece, so....you can understand my confusion. I'm just trying to seperate fact from fiction. Everything so far points to them weighing in at 14 lbs per tire which would be 6 lbs heavier than the MT. That's a weight penalty that cannot be ignored. So, I guess my question now would be "do the benefits outweigh (no pun intended) the detriments?" 6 lbs is a huge amount of weight to add. As far as it working, I'm sure it does work. The question is, how well does it work? There are more factors for me to consider than just handling and ride quality. I'm interested in performance, also. If, by adding 6 lbs of rotating mass, it adversely affects acceleration and braking, then that needs to be taken into consideration, also. I'm not sure I'd like to give that up. I'm 85% sold on this mod, but there's that small amount of indecission that's keeping me from going to the Darkside. I realize that you're an adof this mod, however, some of us need a bit more convincing than others.
Ride safe, ride often,
Gearhead3
Gearhead3
#375
#377
Good point, but I've just installed the FM 107 and would like to keep the performance I've gained with it. I'm sure I'll do the CT, but I'd like the performance to at least stay even, not take a step backwards.
#378
#379
#380
Not trying to convince you, its not my job, these are simple facts.
The only thing wrong with using CTs? the naysayers,
Regards,
