Went to the Darkside(car tire)today
#1301
i UNDERSTAND YOU MIGHT MODIFY THE FRAME TO INSTALL WIDER FENDER IN ORDER TO INCREASE WIDTH OF TIRE! A FRIEND HAS AN OLDER BIKE AND BOUGHT A LATE MODEL SWING ARM FOR WIDER TIRE AND LATER FOUND OUT BOTH BIKE TAKE THE SAME SWING ARM. HE PURCHASES A REAR CLIP AND PLANS TO CUT FRAME AND REPLACE WITH LATER MODEL AND WELD. A REAR BRAKE CALIPER CHANGE OUT MAY BE REQUIRED. IF YOU FIGURE OUT BEFORE I DO. PLEASE SHARE WITH ME AT STURGISHERB@YAHOO.COM. WE HAVE 07 FLTR AND 08 ULTRA.
#1304
#1305
#1306
I thought I posted this before but I guess not.
As suggested I read all the posts in this thread. Read every other post/note/comment I could find. There are as many pros as there are cons. I can see this as your either on one side of the fence or the other.
My decision is based on Harley greed to get every dollar from you even when buying tires. Since when are you restricted from buying OEM tires other than from Harley? It started my hunt for options and here I am. I'm looking for a tire that will safely get more than one trip/season and good traction.
I opted to try it. Iv'e got a few hundred miles on it and have only noticed an issue with cornering on a certain spot on the tire. Could be the tire I used.
It's smoother, tons of traction, tracks straight and a little softer ride. Also lighter by a couple of lbs.
My real test is a 6-7k trip in another week. I will be as objective as possible with my findings.
I'll be back in a few weeks and let anyone interested know how it turns out.
09 RK, General, G-MAX, 195/55/16
#1307
I think that was a pretty highly regarded tire there as I recall, but I just gotta ask; just WHAT are these "cons" you speak of?
As far as I and 98% of all Darksiders are concerned, MT's are UNSAFE on the rear if you really like to whip that thing. At least you noticed the immediate improvements, and I'll be looking forward to hearing the rest of it after your trip. I betcha don't go back!
#1308
#1309
Make sure you get the air pressure adjusted to your sweet spot. A couple pounds of pressure can make a big difference. I keep mine between 30 -32 pounds, but everyone is different.
