Dead FOB battery almost left me stranded - 2010 RK
So there I was, putting gas about 1 mile away from the customer site, just before going on site... I usually work from home, but needed to pay a visit to this customer to check some T-1 lines...
Anyway, after replacing the pump and gas cap, putting glove back on, getting back on bike, turn ignition switch to on position... I hear two chirps from the alarm, both turn arrows go on simultaneously on the dash... WTH... two more chirps... press the Start button... nothing... alarm starts wailing... crap! I turn ignition to off position, alarm is still wailing... WTH!
Set bike back on stand, turn wheel to left, and alarm eventually shuts off after a little while. Tried different things with the key (locking/unlocking), same deal each time. I'm starting to get worried... I don't remember how to get to the disarm code sequence.
FOB is in my pocket... take it out, shake it (in case battery is loose or something). Same thing - alarm keeps triggering.
Take out the manual (luckily I kept it in the saddlebag)... flipped to the alarm card page... disarmed the alarm using the code and instructions, turned bike on and went to work without issue . After work - same thing again, but I was ready with the disarm sequence this time.
Got home, got the spare fob, brought it close to the bike, everything worked fine. Switched fobs on my key ring... replaced battery on the other fob, and it worked fine as well.
I just purchased my new 2010 Road King in September - this year, less than two months ago... am I doing something wrong to deplete the FOB battery so quickly? Did the dealer just give me a fob with a bad battery? Or is this normal FOB battery changing time for a 2010 model? The battery in my truck's FOB has lasted literally years with constant use... bad battery in the FOB to begin with? Don't know...
Anyhow... Just a reminder to replace your batteries before they go bad... and know your code and how to disarm your alarm and ignition cut-off just in case
Sorry for the long post.
Just happened to me, too. I had just done some lighting mods, added a load equalizer, and thought I messed something up. Just the fob battery. Fortunately, I had the card from the back of the owner's manual in my wallet with my code. Mine is an '08, though, and this is a first for me. So no battery life problem here.
Still haven't changed the battery in the other fob. Guess I better do that today. Thanks for the reminder.
Remember that the H-D fob transmits constantly (24 hours a day, even though it is at a fairly low power), while fobs for passenger cars generally only transmit when you press the button to unlock the doors.
I believe there are exceptions for some of the newer cars that don't use an ignition key, but then they likely will run into similar problems that the H-D fobs have. My friend has a new Infiniti that is keyless and apparently works the same as the Harley (you must be within a certain proximity to the car to start it or unlock the doors.) However, if the battery goes dead, you can still start the car by using some small magnetic "key" that is part of the fob.
