SG Sadona Orange Painted Inner Fairing (PICs) Easy Install
Just wanted to share my experience installing my first painted inner fairing,
Very easy job, took about 2 hours even for a shade tree mechanic. This is on my son's FLHX, I will be doing mine as soon as it arrives.
Remove outer fairing (7 screws, headlight connector), Remove Cap and switches (2 screws, 1 nut on ignition switch), Remove blinkers (4 screws), unplug connectors from 6 gauges, remove the speakers (3 screws on each), Disconnect clutch cable from lever (snap ring), Remove Odometer push-button (Remove rubber cap and nut),Remove 4 screws from inner fairing and it's off. Now just remove the gauges (2 screws on each). Reassemble in reverse order.
I like the looks of a painted fairing. My dealer was going to replace mine on my 09 SG because of fadeing. I took it to my painter. They installed it for me for free. Don't want to put the windshield bag back on now. Took the dealer over 2 hours to do. They orginally said it was about 1 1/2 hr job. So you did real good at 2 hours.
To do it in 2 hours that's fast especialy if it was your first one.
It took me about 4 or 5 hours I had to take a break half way into it and I finish it the next day. I took my time and marked all the conectors only to find out the conectors are almost idiot proof they only fit into the right conection.
Now that I have done one it would only take about 3 hours and that's what I would charge someone if I had a shop.
