2010 Limited - I have water in my rear fender tip light
Old 11-04-2010, 10:29 AM
chevele72's Avatar
chevele72
chevele72 is offline
I had the smoked one on my '09 and they warrantied it. And as said it is a "somewhat" sealed unit.
Old 11-04-2010, 10:42 AM
my67pnycar's Avatar
my67pnycar
my67pnycar is offline
I would take it back and let em replace it under warranty. Good luck.
Old 11-04-2010, 01:46 PM
cooper57M's Avatar
cooper57M
cooper57M is offline
not same bike, but my street glide fear fascia running light let in water made my light fail. It was out of warranty so i bought the run / brake light version. Like past posters have done, i ran a bead of silicone where the wire go into housing to further waterproof the light.
Old 11-04-2010, 01:49 PM
dansflhti's Avatar
dansflhti
dansflhti is offline
I have the run/brake model on my 09 Classic and have driven in the rain quite a bit,and wash her a lot too,but no problems yet.
Old 06-23-2011, 07:43 AM
Stansuski's Avatar
Stansuski
Stansuski is offline
Just installed run / brake version , washed bike after rainy week in laconia,it now has water in it.I will bring light back for replacement and will seal perimeter of lens as that is where it is leaking. Amazing that a 2+ year old issue is not redesigned by the Motor Company.
Stan.
Old 06-23-2011, 07:49 AM
hojones's Avatar
hojones
hojones is offline
I fixed mine by using a very small drill bit and drilling a hole in the left side bottom so the water will drain when bike is on side stand. Doesn't keep it out but cures it for me.
Old 06-23-2011, 11:15 AM
blue flht's Avatar
blue flht
blue flht is offline
Mine does it had it replaced and it still gets water in it, may have to just drill a small hole in it.
Old 06-23-2011, 04:33 PM
DrPlastic's Avatar
DrPlastic
DrPlastic is offline
As said before it is is normal. What I did was to pop off the lens, clean up all the water and squeeze a large blob of dielectric grease in the socket. insert the bulb and a bit of the grease will ooze out. Then take that and build up a bead around the base of the bulb to seal out water from the socket
Old 06-23-2011, 07:27 PM
Stansuski's Avatar
Stansuski
Different light on 2009 and newer
,Stan
Old 11-25-2011, 09:22 AM
OldFordTrk1's Avatar
OldFordTrk1
OldFordTrk1 is offline
After reading this topic, I went to check my new to me bike, only 4 weeks old (for me, 2010 Ultra Classic), and I too had water in the rear tip light. It's just out of warrenty and was just fixed by the dealer for failed rear breaks due to the recalled switch. A new one was almost $100 so I just decided to install my own LEDs in the orgional housing. It will come apart, but not easily. I disassembed it, removed the led board and drilled the chrome piece to press fit my 0.400" diameter red LEDs in from the back. Sealed it back up and wired back up. Now it works as it should and I know it is water tight! I love the bike, just a little worried...owned for 4 weeks and already had two issues! What's the next issue to come up?
Quick Reply: 2010 Limited - I have water in my rear fender tip light
