Anyone NOT like 12.5" Wild 1 apes
Old 11-06-2010, 07:46 AM
greglal's Avatar
greglal
greglal is offline
+1 WO577
+1 Namz
+1 +6" Cables
And definitely +1 on fishing the wires through then adding the extensions with 1 addition, connect the extensions to the connectors first then connect the extensions to the wires after you fish them through the bars.
No regrets on the WO577s at all, but I'm sure I would have had no regrets with the 14" either.
Old 11-06-2010, 06:15 PM
'05Train's Avatar
'05Train
'05Train is offline
Originally Posted by greglal
+1 WO577
+1 Namz
+1 +6" Cables
I'm considering swapping my 575s for 577s. Could you explain what you mean with the extensions?
I'm assuming you mean to run the wires from the grip ends through to the center, then put the plugs back on, or the extensions?
Old 11-07-2010, 05:26 AM
greglal's Avatar
greglal
greglal is offline
What I mean is, after you run the wires through the bars, before you connect the extensions to the original wires connect the extensions to the molex connectors first. Then connect the other end of the extensions to the original wires. The reason is that it will be much easier to reassemble the molex connectors while the extensions are not connected to the bar wires.
Old 11-07-2010, 07:10 AM
DocDyna's Avatar
DocDyna
DocDyna is offline
Default My Thoughts EXACTLY
Following my previous post in this thread, some said "save your money on the extensions" Well ....Thinking ahead maybe someday I want to go to taller bars, then I'm all set. I could have gotten away with shorter or no extensions, but for the little cost of adding them and the ease of fishing wires through the bars, I wanted the longer wires.Plenty of room under fairing to roll up the extra length and cable-tie. I am always making changes to rides, plus 35 yrs as an Electrical Eng in Industry has given me some fore-sight with wiring and allowing for future mods.
Old 11-07-2010, 07:17 AM
'05Train's Avatar
'05Train
'05Train is offline
Gotcha. So the extensions already have the Molex pins on one end and you crimp the other end to the bar wires?
Old 11-07-2010, 07:19 AM
greglal's Avatar
greglal
greglal is offline
No crimping, just a push/snap-in connection. Then you heat shrink tube them (included).
Old 11-07-2010, 08:55 AM
'05Train's Avatar
'05Train
'05Train is offline
Oh that's too easy......
Dammit, now I have to change bars again.
toprat
03-15-2014 07:56 PM
justjoshin84
04-22-2013 07:47 PM
CVORoadKing2013
12-29-2012 04:17 PM
Brawny MMC
04-08-2011 06:48 AM
DWhite
09-07-2010 11:40 PM
Quick Reply: Anyone NOT like 12.5" Wild 1 apes
