Loose Tour pak rack
Yes it is a detachable rack. The rack itself is what is loose, there is a little fore and aft movement at the securing points. The rear release points are fully engaged, but if I put a little pressure on the trunk, i.e. lean back against it, it will move. The trunk mounted to the rack is solid.
I had a '07 RG with the detachable tourpack. All the pre-'09s have the same problems as it's a poor design and worse execution. The front mounts are steel slots sliding over a steel bushing with a rubber insert in between, and they will wear thru the rubber. The rears will wear thru the bushing. Even worse - the tolerances are huge, as these racks are made all over the world in sub-standard fashion. That results in some tight fits, some very loose ones.
Gilbos sells aluminum replacement bushings, but he still has to make them undersized to fit the narrow-slotted racks. Even if they fit tight initially, a steel rack vibrating on an aluminum bushing wears substantially in not very many miles. So you rotate the bushing and wear it someplace else....
I finally ordered some Delrin plastic stock and turned my own bushings on my lathe - Gilbos' idea but with better material. I also had the rack right there, so they were custom-fit to match. That virtually eliminated the slop, and Delrin is used to make bushings for industrial machinery (replaces bronze and wears much better). I made a set for another guy here on HDF, and he has 10k miles and an accident that destroyed his original tourpack on them - still nice and snug.
BTW, any interest in making another set of Delrin bushings?
Just to update this thread. I swaped out the docking bushings and I still have the movement. I have a sneaking suspicion that that rack is aftermarket and not a genuine HD product (bought this off of Ebay) and that the securing mechanism is just a bit larger than the OEM stuff. I'm going to see if I can purchase just the securing "hinges" from the dealer and see if that makes a difference. If not then I'll probably see the rack on Ebay and buy a Harley one. As it is I can still ride with it, but I'm particular about my bike and this will bother me if left alone. Thanks again for the advice and suggestions.
Even the "genuine" HD ones have substantial variance. Ride the bike over to the dealer and try another rack on it.
If you have a precision measuring device (dial caliper from HF works fine) and can give me the diameter you need, I can whip you up some delrin ones. Mine were .030 larger than stock, and I did a set for another member that were +.045 or so.
