Anyone having trouble shifting on 2010?
I have about 3K miles on my 2010 EGC and always felt it did not shift right all the time, even after warmed up.. Mostly from 1st to 2nd and not all the time. Sometimes I get the clunk and shifts easy but other times it seems like you need to stuff it into place. The best I can explain it is sometimes the shifter will travel up a half inch or so and other times it feels like it moves very little but does go into gear. Sort of feels like shifting into sixth gear when you only had a 5 speed, after a while it is hard on the toe. Other times on the downshift it feels like two clunks as if it starts into the lower gear but needs a little pressure to finish. I put Redline, Royal Purple and Syn 3, not much difference in any. I will be taking it into the dealer this week but looking to see if anybody has already had this kind of issue. Thanks
I should have added that I adjusted the clutch several times trying backing it out 1/2 turn, 3/4 turn and 1 full turn. If you can imagine what it would feel and sound like if two gears had a piece of thin material over it. Like it is too tight to fit but quiet also and only some of the time. Some days hardly at all and other days maybe 25 to 50% regardless of outside temp.
I have a similar feel with the 3-4 and 4-5 shifts. Sometimes the shifter movement feels too short other times it feels right and sometimes it's almost impossible to find neutral. I have even had to use my hand to try and shift to neutral. I'll be asking them to check it at the 1K service on Tuesday. If they find anything I'll post it.
I can not find neutral , it takes alot of time when I stop to get it , I am hoping as it wears in the Neutral will be easier to find?? I also have a clutch that has all the clutch on the last 1/4" ?? That takes some getting use to , I will have to adjust the clutch and hope that gets rid of it? How do you do the clutches adjustment? What does it help ? Thanks for those answers.
I was using Amsoil 75-140, and had a ton of chatter and slip, as well as a very inconsistent pull. Switched to Drag Specialties Primary Fluid and most of my issues went away. I also stopped using 38 ounces and just fill to the bottom of the clutch. I still think there's an issue in there, bit it's much better than it was.
