How Many Miles Before Dyno
#32
Ed,
It wasn't a stock ecm. It was a SEPST "starter" map for an HQ113 that the tuner has used before. In fact, it's his start map that he uses to tune every HQ113. It still wasn't good enough to do any real miles on............
That, or touch it up on the dyno before turning you loose for breakin.
You are saying that he has a poor starter map, yet he uses it on all his builds?
Why no horror stories? Not everybody posts the internet.
#33
That is precisely what I try to avoid.
Too fat is far worse than too lean (despite urban legend) because it can and will wash the rings out, wash the oil from the cylinder walls, and contaminate the oil.
But that's just me.
How others do it is totally up to them. What ever floats one's boat. To my, all that matters are the motors I build and/or own.
But that's just me.
#34
Anybody ever hear of "micro welding" the rings? Comes from overheating them during breakin.
You end up with less power and you won't know why,.... until you put your rings under magnification and see little aluminum specs on them (that came from the pistons). Only cure is to replace the pistons.
I wonder,.... how many people build a motor, and don't get the dyno numbers they were expecting?
Ever hear of that happenning? Surely you've heard of them, met them, or was one of them.
Most think they just had a bad tune or bad luck.
How many put their rings under a magnifying glass?
#35
aceckel
05-24-2010 10:31 PM
