Anyone turn a 96" into a 103" with S&S 551 or 583?
What is your compression ratio?
Are you running flat top pistons only?
Reason I ask is I talked with S&S and they are planning to re-label the 551 as a bolt in to stock motors (less than 10:1) cause the compression the cam adds, it may have detonation issues. but they would not tell me not to use the combination...
what is your current cam?
that's not what I understood from S&S; they said that the 551 was designed to close sooner adding to the compression. something about machanical vs running. they did not want to have the machanical above 10:1, the added compression caused by the cams would cause excessive pressure, potentially causing detonation.
Cams don't increase compression. Shorter duration cams just allow for less loss of running compression.
1 Post
Static Compression vs. cam intake timing
I still can't get it through my pointed head how cams with "built in advance", like Harley's SE204, increase static compression. Team Lattus had a Forum answer long ago on how the 204 cams' 4 degree advance (intake is 22/34, vs. Andrews 37 with intake 18/38), resulted in higher static compression and more power on stock motors. A friend who used to manage a local Harley dealership ran them as high as 10 to 1, but beyond that pre-ignition was a problem. I am running a set at 9.9 to 1 in my trike, but am about to change them out for S&S 551 torque cams, as I pull a camper. I just read that S&S is recommending that they not be ran above 10 to 1 because of the static compression that the 551's make (intake 17/19 with intake centerline at 91). -Just trying to understand, thanks!
