Who has the best deal on Corbin Seats?
I purchased mine from Tri County HD in Ohio and it was 20% off list. I believe Jenny was the person I spoke to and ordered a dual touring corbin for my 09 SG and really love the seat.
http://www.tri-countyharleydavidson.com/
Give them a call and see if they still offer the price discount.
Good Luck
Good Luck
Good Luck
Good Luck
There are several resellers that have them for 20% off. This is a good one:
https://www.mandmcycles.com/homepage.htm
If you order directly from Corbin you can get options like cover patterns, studs and if your lucky to be close enough to one of their two factories they will custom fit it to your inseam at no charge.
Took only a week or so to receive the seat. Planned to take it for a ride, but checked the tires first. Found 10 lbs. in the back tire and a nail. Second flat in 3400 miles, glad I have tire and wheel on the extended warranty. Took it in to the shop for that and other issues and took a while to get it back because they had to order an o2 sensor.
I've ridden it several times now including this morning to work at 25 degrees. I like the seat a lot. It was instant comfortable and didn't need any break in. I wondered if the heat would be worth it because I always felt that my rear wasn't what got cold, but it does feel good on a cold day. I explored my attic and found that I hadn't traded the backrest of my old Corbin when I traded my Bad Boy in 2000 after all. It was a nice surprise to find the backrest can be installed, adjusted, or removed from the topside now and it also tilts forward for passengers. Not as clean as the Harley backrests, but still nice.The backrest on my old Corbin had to be removed from the bottom and couldn't be adjusted.
Thanks for the help guys, I'm happy!
Eric
Eric
