What's it like to own a well tuned 107?
So I've talked to a reputable indy a few hours from my house, and I have a build I'm thinking about doing this winter. Should end up with about 125tq/110hp. Right now my bike is basically stock so the difference should be amazing. I want to be able to pass traffic without having to plan for it. Just twist and go like on my sportbike. I also want to be able to pull away from my buddies on their stock Limiteds and CVOs when we're riding in the mountains.
For those that have upgraded to a 107, what is your impression of riding it? Any regrets? Are you satisfied with the performance? Any problems? Would you do it again?
My biggest concern is longevity, since I ride about 20k/yr. I also need it to retain good low speed manners for when I teach MSF ERCs on it. I'd like to get 100k out of the build before any major work is needed. Am I hoping for the impossible?
Any input is appreciated. I'm in the justification phase of the build now.
The build:
Bore stock cylinders
Bore stock throttle body
Stage 3 Head work on my stock heads
Forged CP Pistons
Adjustable Pushrods
Woods TW5-6 cams
Clutch lockup
D&D Boss Fat Cat 2-1
TTS Master Tune & Custom Dyno Tune
The build:
Forged CP Pistons
Adjustable Pushrods
Woods TW5-6 cams
Clutch lockup
I have a T-Man Performance 103, stage two heads, forged Weisco pistons, 625 cams true duals and Reinhart 4" mufflers. I wanted to go with the stage 3 107 setup also but my crank run out was a little more than wanted. I wanted reliability more than anything else so thats what I did. I'm very pleased with the performance and hope it will last for a good while.
The build:
Forged CP Pistons
Adjustable Pushrods
Woods TW5-6 cams
Clutch lockup
The build:
Forged CP Pistons
Adjustable Pushrods
Woods TW5-6 cams
Clutch lockup
Your Indy has thrown together?
Or a package that one of the performance companies have put together that's known to run?
You can't/shouldn't just go throwing parts together for a hot rod motor.
If the parts don't work together, you're in worse shape than when you started.
I'd suggest letting the Indy do the assembly...and a performance company putting the package together.
Head-Quarters
T-Man
Hillside
GMR
These companies have proven packages.
Look into them...then decide.
Is "The Build" a package you've thrown together?
I'm interested in hearing how others feel about their builds. Do they have the performance they were looking for? Are they satisfied or do they want more power? Any issues, problems or regrets? How long can I expect it to last before major work is required.
Nothing has been "thrown together" It's a package that Andrew Rosa has put together many times. I let him choose something he knows works. I'm not worried about the build it self.
