Can you replace heated grips with something cooler
Old 10-26-2010, 06:57 PM
arlinsg's Avatar
arlinsg
arlinsg is online now
On my old RK, I went to the Polaris dealer and bought some inserts that they use on snowmobiles. I think they were about 39.95, but they only have a high and a low setting. They worked fine for me for about 8 yrs.
I believe the brand was Polly heaters, I just wired them into my acc. switch.
Old 10-26-2010, 07:00 PM
D'Artagnan's Avatar
D'Artagnan
D'Artagnan is offline
Originally Posted by head
can you share your procedure with us please?
off topic-isnt that mountain behind you called the ****?
head
See Dawg's post #10.
That's Pilot Mountain from Hwy 52. Near Mount Airy -- Andy Griffith's hometown.
Old 10-27-2010, 05:09 PM
head's Avatar
head
head is offline
havent been there in years. i thought thats what it was. i guess the **** is basically the rock itself on pilot mountain. thanks..
head
Old 10-27-2010, 06:47 PM
2011FLHTK's Avatar
2011FLHTK
2011FLHTK is offline
Originally Posted by dlrshort
My understanding is that you buy replacement Heated Grips (with wiring) that will replace stock grips and wiring from the old grips. You need to buy the complete assembly.
Kuryakyn makes this for Goldwing grips. It's a clamshell that fits over the existing grip. I don't think they make anything for harley. It would be nice if they did. It is an expensive, PIA I would think to change over the grips.
http://www.kuryakyn.com/index.cfm/go...ID/64/IMID/275
Thanks for the info. Those clamshell grips look good, but the Harley heated grips have the controller on the end of the grip and these Kuryakyn grips have closed ends. I don't think they will work with the Harley heated grips.
I know we would have to buy a complete HD heated grip kit (with wiring) if we want to change from our stock grips. I don't mind buying a kit that comes with all the wiring, I just don't want to have to change the wiring. It would be great if the heated grips unplugged from the wiring at the grip end of the wiring harness. Does anyone know if this is possible?
Old 10-27-2010, 07:10 PM
hardwork2's Avatar
hardwork2
hardwork2 is offline
I too have ugly grip disease. I'm going to Check with Iron braide and see if they can wrap them, If that dont work I thought about getting some stingray leather and wrap them in that, Just a thought.
Old 10-27-2010, 07:16 PM
hotpursuit's Avatar
hotpursuit
hotpursuit is offline
The wiring harness is attached to one of the grips, it plugs into the other... So technically no you would have to rewire them. But, you probably (I haven't tried) could cut the harness and splice the new ones in, if you do that I'm pretty sure they won't warranty them and I have seen quite a few fail.
I'm thinking bout trying a set of heat demons, but honestly thing the gerbing heated liners would do better than a heated grip. And if you have more than one scoot you can easily have your gloves with you on any without a complete reinvestment.
On really cold days palms of the hands are warm, and the tops are cold.
Old 10-27-2010, 07:32 PM
2011FLHTK's Avatar
2011FLHTK
Thanks for the info. Probably could splice it, but at $300 I'd hate to void the warranty.
Old 10-27-2010, 09:09 PM
hdramon07's Avatar
hdramon07
hdramon07 is offline
I've been looking at a new Limited for a while now, & that is a question I've asked both sales & service. They say for now it would require a complete install on a new set of heated grips.
The stock grips are not only too plain, but for me they are too small in diameter.
Old 10-27-2010, 09:44 PM
2011FLHTK's Avatar
2011FLHTK
I might try some leather wraps. They add some diameter and don't look as plain.
Old 10-27-2010, 09:47 PM
voodoodrug's Avatar
voodoodrug
voodoodrug is offline
You can get the electrically heated wrap cheap and if your good with electronics or have a friend that is ,make them yourself. Lasts years,cheap...
Ultra103
12-05-2023 09:01 AM
whiskeyfire
01-26-2019 11:59 AM
rleggs
11-24-2014 07:24 PM
Rdgray
01-18-2014 03:53 AM
gdbice
07-31-2012 01:23 PM
Quick Reply: Can you replace heated grips with something cooler
