Sears Yellow/Red Jacks
Old 10-25-2010, 01:41 PM
BoomerBob's Avatar
BoomerBob
BoomerBob is offline
I can't stress enough how important it is to put the bar through the holes on the aluminum jack and rest it down on the bar. Up till then the bike will be wobbly. Once rested it's very stable. The beauty of the aluminum jack is its light weight and how the handle is also fluid release control.
To each their own though. Gotta go with what you are comfortable with.
  #42
Old 10-25-2010, 02:18 PM
Bluegrasser's Avatar
Bluegrasser
Bluegrasser is offline
How does the red/yellow jack handle a major shift in weight and balance like when you remove one of the wheels? I won't use the jack often which means a Sears jack makes more sense, but I will be removing the wheels with it so if that means I need a J&S/Pitbull then that's what I'll get.
  #43
Old 10-25-2010, 03:17 PM
Keithhu's Avatar
Keithhu
Keithhu is offline
Received 5,609 Likes on 2,727 Posts
I had the yellow jack and wouldnt even think of changing wheels on it, it was scary wobbly enough just sitting there.
Went with the J&S and now I can climb on the thing without straps, and without a hint of worry (the J&S video don't lie!). No more stressful moments with the J&S jack.
  #44
Old 10-25-2010, 03:43 PM
09ultraclassicrider's Avatar
09ultraclassicrider
09ultraclassicrider is offline
I have had the sears red jack for a couple of years now. It works just fine. I have had the bike up in the air with the front tire off and it was not an issue.
  #45
Old 10-25-2010, 04:20 PM
Crusing's Avatar
Crusing
Crusing is offline
Originally Posted by Bombarde32
Hi all. Getting ready to do my 20k miles service on an '09 Electra Glide but I still need to get the jack. Wondering if anyone has experience with the yellow or red jack from SEARS, how good they are, and what the "real" difference is?
I don't care about turn tables or anything fancy. I just need something to reliably go up and down. Reliable being the big thing because I hate having to purchase things twice because I bought garbage the first time around.
I have used the yellow jack for about 4 years. Good service and no problems.
  #46
Old 10-25-2010, 06:35 PM
Blackheat's Avatar
Blackheat
Blackheat is offline
had a 100 buck jack didn't like it gave it up and spent $$$ on Pit Bull, no worries now!!!
Attached Thumbnails Sears Yellow/Red Jacks-bike-10-16-2010.jpg
  #47
Old 10-25-2010, 07:25 PM
FLoTR's Avatar
FLoTR
FLoTR is offline
I have buffed, polished, and wrenched with it on the RED jack. It's been on it for up to a week. Have to admit I was nervous at first but after it teetered all day during a detail,,,,, it ain't gonna fall unless you screw up.
  #48
Old 10-25-2010, 08:23 PM
dirtracin23's Avatar
dirtracin23
dirtracin23 is offline
Originally Posted by Doug45601
Since 1994 I've owned all sizes of Harley's from Sportsters to Ultra's Also have owned and used Jacks like Larine, Sears Red and Yellow, J&S, Pit Bull and a Harbor Frieght.
Ive only used the Jacks for general maintenance and storage but can tell ya the Pit Bull was superior for me on the stability whereas the Lorine (sold at tractor supply) was the poorest excuse I ever used for a jack.
Back and forth on different bikes and jacks throughout the years has always bought me back to the Craftsman Red Jack... Not because it's the best but because I feel it the best value for the dollar! Furthermore, if you just need to lift the bike for occassional maintenance work, cleaning, and or storage then why buy the house when an umbrella will do?!
The argument between the Sears Craftsman Red vs the Yellow is: wieght, low profile and looks however, the hydraulic pump on the Yellow jack is "specific to the jack itself" meaning it's non-exchangeable. Also the Yellow jack's construction lends to more wobble then the red jack.
All said and done... Yes the pit bull and J&S are superb motorcycle jacks and are made for the daily wrenchers but for me are somewhat overkill for my needs.... so check your needs, check your wallet, double check your piece of mind then make your selection! Be it hot dogs or steak.... it all turns to shi... well you get the idea.
This may very well be the best response I have read on any thread concerning bike lifts.
  #49
Old 10-25-2010, 08:58 PM
LA VIC's Avatar
LA VIC
LA VIC is offline
Excuse my ignorance Boomerbob but what bar and what holes? All I have is the main jack handle. Don't see any holes through the linkage that could be used to stabilize this puppy. Help a brother out.
  #50
Old 10-25-2010, 09:10 PM
CT-Bagger's Avatar
CT-Bagger
CT-Bagger is offline
Oh did I mention?
Sears jacks are junk.
J&S jack are not junk.
End of story.
Hook, line, sinker, DONE !
Quick Reply: Sears Yellow/Red Jacks
