LED tour-pak Brake/Turn/Tail light kit
I wanted to add a little more safety features so I purchased the conversion wiring harness (PN 69200042) to make it happen. I should have looked more closely because it states for bulbs and mine are LEDs. I see Harley has a complete LED setup (67932-11) for cost $469.95.
Does anyone make a wiring harness conversion kit for those with LEDs? I can't see paying $400+ when my bike came with a LED light bar.
You might want to check with Keith at http://www.ridetimetechnology.com/ and ask him what he thinks.
What I did with mine was , I use the Badlands Illuminator http://www.ridetimetechnology.com/badlands_ill.htm so I could convert the lower lights to run/turn/brake function.
Then I got thinking , why not add the tourpack lights to the same function.
So I got this http://www.ridetimetechnology.com/qc...er_adapter.htm.
Then I ran 2 of my own wires for the turn signals from the trailer adapter to the large (bright) filaments in the tourpack.
I just cut the wires from the sockets and used my own Brown and violet wires from the adapter.
Now the Illuminator does all the lights , I can switch to led in the tourpack and not have to buy another thing as the illuminator does the load equalizer work for me and will adapt to any combination of lights that I use or add in the future.
You may be able to use the Harley converter with just a load equalizer , but check with Keith first for a maybe easier solution.
Mick
Mick
Mr. Wizard
10-09-2009 03:48 PM
