detach tour pach
Just a quick word of caution. When you take the tour pack off have someone helping you. They are not very balanced and you run the risk of scratching your paint. After you are used to it it's a one person job to take on and off. Just make sure the wiring is disconnected or you will be dragging your bike along with the pak (and no hands left to disconnect them). Wonder how I know that???
Gitarded
Gitarded
This is timely for me. I just purchased a 2011 FLHTK and I want to order the detachable tour pack hardware and wiring harness. The intent is to "Street Glide" the bike when I'm not on long trips.
My questions:
Where do the antennas go (CB and radio)? Do you manually move them each time to add/remove the tour pack?
Where does the license plate go?
How much time does it take to swap between tour pack on/off?
Thanks for your help guys.
My questions:
My questions:
My questions:
The CB antenna I am not bothering with and just packed away the cable under the seat.
The license plate goes on to brackets provided just above the tail light. ( I am looking into a way to get it down below the tail light but it's fine above it).
It literally takes me 5 minutes or less to swap it on or off when using the radio, lights, and rear speakers. If you use the CB add 1 minute. Honestly.
The seat has to be lifted off anyway so when I take it off I swap out my Ultra seat for a street glide seat and whalahh!! you have an instant transformation all for around $700.00 ( including the seat I bought off e-bay which is flooded with them).
Check back this weekend as I'm updating my signature pic with a shot more from the rear so you will see the license plate better.
My questions:
My questions:
I put Hidden Antenna for both CB and AM/FM inside the fairing. This made it easier when the Tour Pak is removed.
I also have the Boom! Audio Music and Intercom Kit (77108-09A). This makes it so my passenger can still have the headset and controls when the Tour Pak is removed. I also eliminated the Passenger CB controls. This makes it so I only have the Tour Pak lights and speaker wires to hide (under the seat) when i take the Tour Pak off.
The two-up docking hardware kit (54205-09) alone does not include the License Plate relocation hardware. It is included if you get the Detachable Tour-Pak Rack Kit (53246-09A) for '09-Later Electra Glide Models. Complete kit includes two-up docking hardware kit, Detachable Two-Up Tour-PakŪ Rack, chrome strut covers, chrome license plate holder, reflector, and AM/FM antenna relocation hardware.
As for how much time required, It took less than five minutes to take off and put on before I moved the antennas inside the Fairing. After I moved them, I could remove the Tour Pak in less than a minute, and it took just a few seconds longer to put back on. This was because I needed to find the Front Docking point. It is Great. Just remember to remove everything from the Tour Pak. It is real heave with it full.
Thanks to everyone for their responses. You've been very helpful.
I find it interesting that H-D will provide documentation on the web site for something as simple as the halogen light bulb kit but they don't provide documentation for some of the more complex items, like the tour pack relocation hardware. When you can see the hardware provided it tends to answer most of the questions you might have.
