Alloy Art 98TS Stabilizer on a 2010 Street Glide
Just finished installing the new Alloy Art (98TS) Engine Stabilier on my 2010 Street Glide. The stabilizer is only about $150, so it is quire a bit cheaper than other versions. This was reviewed in the December 2010 Hot Bike magazine. Overall it took about an hour. I had the Harley heat deflector that install on the frame to keep the engine heat off you leg. I had to take the right deflector off to allow easier access to the space behind the engine by the starter. I also had to remove the battery lead to the starter, so I had to disconnect the battery.
Overall not too hard of a job, I didn't get a chance to ride the bike after I was done with the install.
I'll let everyone know how it works after a ride or two.
Well took the bike out for a ride tonight, but less than 10 miles. Didn't notice any additional vibrations. The ride wasn't really notically different. Maybe a little less bouncy on small bumps. I guess if things have less motion, and don't add vibration, it should be goodness. Hopefully I can get in a longer ride before it gets too cold.
