Lashing bike on trailer--straight up or on sidestand?
Old 10-19-2010 | 06:48 PM
Mike67's Avatar
Mike67
Default Lashing bike on trailer--straight up or on sidestand?
I was wondering which method would be the best for trailering a bike: on its sidestand or straight up. Pros and cons of each method would be helpful.
Old 10-19-2010 | 06:50 PM
okieboyinaz's Avatar
okieboyinaz
Straight up with suspension compressed with ratchet straps. Just my two cents
Old 10-19-2010 | 06:54 PM
07yellowglide's Avatar
07yellowglide
Default trailering
+1 on that thought
Old 10-19-2010 | 07:08 PM
2011 Road Glide Ultra's Avatar
Straight up with side stand in up position.
Old 10-19-2010 | 07:57 PM
parachuter's Avatar
parachuter
Park it in a wheel chock, with kickstand up. Buy two Harley soft straps, put the front lower forks in a choke hold, rachet strap to the floor. Put a rachet strap on both rear floor board brackets, and rachet the staps towards the front wheel chock. You can flip the trailer over and the bike will stay on.
Old 10-19-2010 | 08:03 PM
FDHOG's Avatar
FDHOG
If it's your own trailer, I would strongly suggest WheelDock Chock.
I've transported my bikes a couple of times, and all you need are 2 straps in the rear to keep the rear end from sliding.
Old 10-19-2010 | 09:17 PM
krazy3's Avatar
krazy3
Old 10-19-2010 | 10:35 PM
aviator's Avatar
aviator
+1. I also put a 6X6 under frame and pull the bike down solid against it. keeps everything locked down tight.
Old 10-20-2010 | 06:09 AM
NELS's Avatar
NELS
__________________
Great idea , thanks I didn't like compressing the suspension on my Dyna so I straped to the bottom of the rear shocks and to the bottom of the front also. Some really rough roads coming back from Daytona in N.Y. and the bike stayed nicely in place . I didn't know how I was going to do this on my RK until I read this post. Great ideas at work here ...Thanks again.
Old 10-20-2010 | 06:43 AM
cmhfguy's Avatar
cmhfguy
The 6 by 6 block is a god idea because compressing the shocks is not good.
On the otherhand, uncompressed shocks is not good because the bike will "bounce" with every bump the truck hits during the trip. May as well have driven the bike the distance as the shocks will get the same wear and tear.
Quick Reply: Lashing bike on trailer--straight up or on sidestand?
