6th gear light not working
There may be a cut out switch associate with the clutch. Even when you are in 6th gear, pulling the clutch lever in will cause the the light to go out. There has to be some kind of electrical switch doing this with movement of the clutch and not a mechanical switch associate with the 6th gear itself.
If you can't fine anything, then it's to the shop under warranty. Hope this helps.
FYI - on my 11 SG if im in 6th gear and pull in clutch while moving, the light does turns off.
The clutch might be the place to look. I didn't think of that. My 6th gear light acts like a bitch in the morning when it's cold. for those who say to take it to the dealer: Been there. Done that. "can't duplicate the problem". Ya. ok.
I'll take a look around the clutch because mine is actually happening in any gear when I pull the clutch in to down shift. Only in the mornings.
It's something in the ecm, from what my dealer told me. Mine didn't work on my 010 RG from new, or so I thought. 300 miles later I called and they said bring it in and there is something they can do with their scanner. On the way there it was working, but it seemed it was maybe the first time I wasn't riding in very bright sunlight. It's documented any way now.
