HD 7' Headlamp Trim Ring
Old 10-14-2010, 11:04 AM
jsciullo's Avatar
jsciullo
jsciullo is offline
Default HD 7' Headlamp Trim Ring
I just installed this trim ring (69733-05) on my '09 RKC and there is a gap at the bottom of the ring where it doesnt meet. Is it supposed to fit this way?
Old 10-14-2010, 11:13 AM
frenchbiker's Avatar
frenchbiker
frenchbiker is offline
No, you should be able to completely close the gap but it might take more than one attempt before you succeed. It's a PITA.
Loosen the stock trim almost completely and position the trim ring over it. Then tighten the 2 rings alternatively, until there's not enough room between the 2 ends of the trim ring to tighten the stock trim. You can then completely close the gap by finishing to tighten the trim ring. Here is the result on my bike.
Old 10-14-2010, 11:49 AM
slothy's Avatar
slothy
slothy is offline
ya my gap is tight like shown in fenchbiker's picture, but i have a odd gap in the inside of bezel.
Old 10-14-2010, 12:02 PM
Buzzsaw's Avatar
Buzzsaw
Buzzsaw is offline
Numerous threads on the subject. I found tighten it then loosen the screw squeeze it and tighten again and repeat and I was able to get rid of the gap. One of the best solutions i saw was a guy who used a one of those squeeze clamps gently to assist.
It is a PITA, but looks good when done, with the gap, some get a whistle when they ride...
Old 10-14-2010, 01:26 PM
jackja25's Avatar
jackja25
jackja25 is offline
I used a wood clamp, the kind that you screw together slowly. When space is gone tightened the screw, didnt have to worry about stripping the screw head. Release the clamp finished. 60 seconds per ring tops.
Old 10-14-2010, 02:22 PM
The Old Man's Avatar
The Old Man
The Old Man is offline
I just squeezed it and twisted it back and forth and kind of managed mine. Took a couple of tries but got it to touch.
Old 10-14-2010, 02:44 PM
boom23's Avatar
boom23
boom23 is offline
Hey... Maybe it is designed to be a deer whistle and we did not even know it!!! Just thinking aloud... (joke)
Old 10-14-2010, 06:34 PM
jsciullo's Avatar
jsciullo
jsciullo is offline
Did you clamp the main headlight? Where did you place the clamp. Top to bottom or side to side. The smaller lights when on without a problem. It's the main light that has me buggered.
Jim
Old 10-14-2010, 06:38 PM
jsciullo's Avatar
jsciullo
jsciullo is offline
You must be Hulk Hogan. I can't get it to budge. I've been messing with it got it a little closer but still a decent gap. I. About ready to put it in a vice. . They were not that expensive so if I screw it up I can always buy another. I'm sure Harley sells a little chrome piece that will cover it up for $1000.
Old 10-14-2010, 06:42 PM
head's Avatar
head
head is offline
ive noticed lots of harley designed things that just dont fit right on my bikes. i do the best i can with them and then just quit worrying about it.
head
Quick Reply: HD 7' Headlamp Trim Ring
