HD 7' Headlamp Trim Ring
No, you should be able to completely close the gap but it might take more than one attempt before you succeed. It's a PITA.
Loosen the stock trim almost completely and position the trim ring over it. Then tighten the 2 rings alternatively, until there's not enough room between the 2 ends of the trim ring to tighten the stock trim. You can then completely close the gap by finishing to tighten the trim ring. Here is the result on my bike.
Jim
Haven't really seen anyone here explain how this thing is really suppose to fit. And since I just spent about half an hour figuring out the install on my bike... I figured I'd "chime in".
What you have to realize is... the factory trim ring has to be loose enough for the "aftermarket trim ring/bezel" to slide in behind it. The "aftermarket ring" has a 1/8th inch lip around the inside perimeter. That lip has to fit in behind the original chrome ring "all the way around the perimeter of the light". So... you have to loosen the original trim ring pretty loose. Once you get the new trim ring over the orginal and trace around the back perimeter to confirm the lip is seated (almost like seating the bead of a tire on the rim, or a "C-clip" on the end of the camshaft). At this point, there should be no gap at all in the new trim ring, even without the screw tightened. You should be able to clamp it shut by hand. The problem comes in when you have to open that gap to get to the factory trim-screw with a screwdriver to tighten it. When you spread it open, that means that lip is not seated all the way in behind the original trim ring. Once you've tightened the original trim ring and then try to tighten the "aftermarket" trim ring, it wont close the gap beacause it can't "seat" behind the original trim ring (cause its too tight now). So, you essentially have to leave the original trim ring just loose enough that when you tighten the "aftermarket" trim ring it can "seat the lip" behind the original trim ring and close that gap! Yeah, its a PITA, and you may have to loosen it a time or two to get the "tension" right on the inner ring.
