4" Rinehart End Caps
Old 10-11-2010, 08:33 PM
Egldr05's Avatar
Egldr05
Egldr05 is offline
Default 4" Rinehart End Caps
Is anyone else having a problem with these pulling away from the muffler body? I can loosen the screws and tap them back in and tighten the living $hit out of the screws and after one short ride they're slipping back. I thought about adding a fourth screw to the outside of the mufflers but I really don't want to.
Thanks,
Rick
Old 10-12-2010, 07:33 AM
BigIck's Avatar
BigIck
BigIck is offline
Nope, mine have stayed in place.
Old 10-12-2010, 07:39 AM
My Fix's Avatar
My Fix
My Fix is offline
Default I'll check !
I do not know I'll look when I get home . But I'm having all kind of cherping noises .
Old 10-12-2010, 09:58 AM
shakes114's Avatar
shakes114
shakes114 is offline
im having the same problem
Old 10-12-2010, 10:01 AM
SGLarry's Avatar
SGLarry
SGLarry is offline
I put loctite on the allen screws....we'll see if the end caps stay.
Old 10-12-2010, 10:59 AM
RaceFace's Avatar
RaceFace
RaceFace is offline
Uh oh, I was JUST getting ready to pull the trigger on these. Are the caps themselves coming loose or just the screws? Chirping too? Maybe a loose baffle?
I think I'll hold off until I read more from you guys
Old 10-12-2010, 11:12 AM
Garemlin's Avatar
Garemlin
Garemlin is offline
I hope the Allen screws are better quality than the ones on the hub made versions. They were soft and the head would round out way too easily. Called to get a replacement set and they wanted $10 plus shipping. For screws. Ha!!!!!!
Old 10-12-2010, 11:17 AM
Egldr05's Avatar
Egldr05
Egldr05 is offline
I tried that. The right one seems okay but the left one is still a problem.
Rick
Old 10-12-2010, 11:20 AM
Egldr05's Avatar
Egldr05
Egldr05 is offline
On mine the screws stay tight, the end cap slips back on the outside where there is no screw.
Rick
Old 10-12-2010, 11:44 AM
RaceFace's Avatar
RaceFace
RaceFace is offline
Rick
What about some black hi-temp RTV silicone to keep the end cap from slipping? It's strong stuff and can still be removed if needed. I've used it on the baffles of my boat headers and it worked great. Just a thought....
Quick Reply: 4" Rinehart End Caps
