Those of you with oil coolers, Do you cover them up when its cold out ? I haven't had my 05 EGC very long and ride all year long. Are you supposed to cover up your oil cooler when it gets below---? I have a 20 mile ride to work everyday, and with cold weather coming up, I want to protect my engine. My 95 Dyna does not have an oil cooler on it, and collects a lot of moisture in the oil during cold weather. I just change oil more often to compensate. What's best ?
My Ironhead has a HD branded Lockhart 500 cooler that has been on it since new. It also has a HD cover that goes with it. I keep it covered nearly all the time. The only time I ever take it off is in extreme summer heat or heavy traffic like at a rally.
I'd likely cover the cooler on your EG during the cold...Personally, I don't think it needs it at all, but that's another matter.
I never did on my '05 EGC w/H-D Premium oil Cooler. Do you have an oil temp gauge? If so monitor it and see what the difference is between covered/uncovered and go by that. Cruising speeds i got around 180-190 in winter and 195-205 in summer if I remember correctly.
you dont need to cover it up.. oil only flows through the cooler when reaches a certain hot temp.. i think 285F or so... not sure - i have to look it up... should be in the HD spec
I never cover on my 07 UC for last 54+ miles, it has a thermostat which opens I think around 180-190. My temp gauge never showed higher then 235 degree even in hot days.
