When changing oil, why take off primary cover?
#41
It replaces the inspection cover. I drain the Primary oil from the drain hole, pop off
the Corbin cover and refill with a quart of whatever oil is popular on this forum.
#42
Even if it don't slip, the "more accurate" adjustment leads to smoother shifting and easy to find neutral.
Smoother shifting is almost as good as sex.
#43
The most popular oil on this forum? There are so many popular oil's on this forum, that You must change brands at each oil change. lol
#44
Ok...Great info from everybody!...Went by the dealer and picked up 4 quarts 20/50 HD oil and a filter plus the filter tool....Went home and looked at the owners manual and figured out which of the half dozen bolts was the oil drain and wala! Drained the oil....Used a cut up Bud Light 12 pack (from another night) carton to place under the filter to catch oil spill which worked pretty good. Replaced filter and put about 3 1/2 quarts in the dip stick hole and we're done!....Next is the service manual and some dvds.....Thanks again everybody that posted
#45
just kidding...it's a thought though.
#46
Oils
Mmmmm...I don't know anything about the different oils...Wow!.....All my previous metric bikes have had only crankcase oil....Thats why I took it to the dealer for the break-in service!...This is all great info guys!...another stupid question, just how many different engine/trans oils does my 2010 SG have???....I'm a newbie btw....lol
