Navigation interface
#71
Click on the "Instruction Sheets" pdf in this link from the mfr. of the 35 wire connector for info on inserting wires:
http://www.te.com/catalog/pn/en/776164-1?RQPN=776164-1
As Copyless said, use a small flat head screwdriver to gently pry up, but not remove, the red wedgelock to "open" the connector for inserting wires.
Carl
Carl
#73
It should be fine, they do come apart, it's just not necessary or recommended, so next time do not remove. Did you check the front as I have mentioned after it was back together, to make sure that all pins are all the way to the face of the plug? If you did this and they are, and the lock snapped back, then you are fine.
Now for the future you know, small screwdriver, insert in groove and twist. I want to add one other thing, you actually should not pry the wedge lock, but rather twist the screwdriver.
#75
Make sure when the music pauses that you turn the volume up, as at this time the phone volume will be in effect, and this volume may be down fairly low. You will have two volumes, one for the sound of any input on the radio ie, FM,AM,CD,etc, and the phone volume, which will be for the NIM, but you will adjust this only when the NIM is activated. So I would check this, (I now see that you have an 11) also I believe there are a few bugs with the firmware on the 11's, which I think they are working on a fix for.
#76
NIM installed, radio not recognizing install
I have a 2011 Classic Ultra. I just installed the RT 660, the faring mount and the NIM. At first I didn't get any spoken instructions form the GPS to the speakers. I then read this forum and discovered that the speaker switch had to be all the way forward (speaker light lit) I now have voice directions.
My big Question is the HD Radio supposed to recognize the Navigation interface? if I hit that button on the radio, I get the message that No Navigation Interface is installed. I would have expected teh radio to figure out the NIM was in place and reflect it.
Any help is appreciated.
-Bryan
-Bryan
#77
