Whats the best way to lower roadking
Old 10-06-2010 | 01:32 AM
travisty10's Avatar
travisty10
Originally Posted by STUNU
kingsride is it hard to change the oil in the shocks?
i would like to know as well. i have a 2007 RKC that i want to install my buddies 2007 street glide shocks on.
Old 10-06-2010 | 07:32 AM
Stevaki's Avatar
Stevaki
King, that bike is sweet...
Would those shocks work on a custom
Old 10-06-2010 | 09:11 AM
onaride63's Avatar
onaride63
1 up on bitchin baggers. they dropped my rear shocks 2''. they did a real good job at a fair price.
Old 10-06-2010 | 11:28 AM
El Rey's Avatar
El Rey
Same shock.
Old 10-07-2010 | 11:12 AM
KING'S RIDE's Avatar
KING'S RIDE
yeah shocks are the same and will work for a custom. they way i did the fluid swap was an invention of necessity. i'll do my best to describe it, but you can modify it to fit your setup/garage.
tool you will need: scissor floor jack, brass fittings same size at the brass nipple in the shock, and hose to match, large closed ended wrench, work bench.
to drain the fluid: remove the nipple in the shock and replace with new brass fitting and hose. place that end on the jack. sandwich the shock between the jack and work bench using the closed ended wrench to keep it in place (otherwise it will shoot out when you compress it). compress the shock and the fluid will escape. do this for both shocks.
to put fluid in: turn the shock over so the nipple is at the top. fill reservoir with new fluid and compress shock, air will be forced out of the shock so be prepared for bubbling. slowly release pressure and the fluid will be drawn into the shock. as you compress the shock again you will experience more bubbling. the shocks hold about 10 oz of fluid.
This is by no means a professional way to do this. it was simply me adapting to my surroundings and making it work. i can take some pics if that will help you guys, but there are some other threads, like this one https://www.hdforums.com/forum/touri...oday-pics.html you can find by doing a search.
this setup is similar to mine, but like i said you gotta do what works for you and your surroundings.
Old 10-07-2010 | 12:43 PM
STUNU's Avatar
STUNU
Holy sh-t kingsride i just had this weird felling i was back in algebra class and alls i heard was blah blah blah , lol , my adult add is kicking in. Thanks for the info but that might be a bit much for me to tackle. Im pretty mechanicly inclined but???? Still gonna find some street glide shocks though.
Old 10-07-2010 | 02:20 PM
Stevaki's Avatar
Stevaki
I know its the same shock but the customs come lowered from the factory. Would the SG shock make a difference?
Old 10-07-2010 | 06:25 PM
KING'S RIDE
yeah i had that feeling when i was writing it. its really not that hard. If your mechanically inclined you can figure a way to do it. you basically gotta compress the shock to flush the old fluid out and pump the new stuff in.
that i'm not sure about. mine was a classic, and had 12" shocks on it. there should be a part # on your shocks. i remember something about if it ends in an A they are 12", and in a C or 9 11".
Old 10-08-2010 | 11:07 AM
Stevaki's Avatar
Stevaki
Alright thanks kings, Ill check that out
Old 10-10-2010 | 11:38 PM
STUNU's Avatar
STUNU
will a stock set of street glide shocks off an 07 fit my 06 roadking flhr?
HedleyLamarr
12-03-2018 12:20 PM
SnoRider
12-26-2015 09:50 AM
DeneFXDWG
02-18-2012 01:30 PM
hoethree
04-07-2010 06:32 PM
Garemlin
08-19-2009 05:39 AM
Quick Reply: Whats the best way to lower roadking
