EZ-Up Center Stand vs. Harley Center Stand (PN 91573-09A)
Using the HD centerstand, I was never able to put it on the centerstand while still on the motorcycle like some can with the EZ-UP, but then again, the rear wheel is off the ground. I would use the jiffy stand to dismount, then holding the left handlebar and the left rear saddlebag protection bar, pull to the rear. Never a problem
As stated before, the H-D centerstand will NOT work with the H-D premium oil cooler and you can go up onto the EZ-Up stand while still in the seat and can usually drive off the stand.
have one of the E-Z ups on my 2013. i bought it for my 2010 but for some reason it wouldn't go on. it went on my ultra classic limited in no time at all. installation took about 2 minutes. nice to know about the transmission fluid. guess i'll remove it prior to taking it up to the dealer for my 1000 mile service.
cass
cass
cass
cass
I just installed the E-Z UP on my '09. It would not go on until I ground off some of the square lip edge. The lip was about 1/16" too wide and was hitting on the frame. It now fits well.
FYI. I purchased the rivco center stand for my bike! IMHO it is a high quality stand, and looks better than the EZ up, only thing was they said I could use the drive off feature on my 09 SG but that won't work. Raises the back tire too high? It also has adjustable feet, but that doesn't help going down! Now with that said I just installed ultra air shocks for more travel, and now works great.. I would take a good look at it.
I like that with the Easy-Up stand I can raise my bike while I'm still in the saddle and when it's time to leave ...just put it in gear an go....
Ditto on the Harley Stand. I HAD one on my '09 Ultra and the last time I attempted to put it on the stand, the left and right legs on the stand went different ways causing the bike to fall over. The interconnecting shaft on the Harley stand broke and there is no repair parts available for it. Harley was always a Pain in the _ss to use too. I am 100% happy with my EZ-UP stand though, wish I hadn't wasted the $$$ on the Harley "Junk". Harley Stand also a pain to install, EZ-UP is a piece of cake. Easy enough to take off if you wish to remove it for servicing the transmission but I leave mine on and don't have any problems getting to the drain plug. Give EZ-UP a call to order and mention this forum to them, I did and got a 10% discount on the purchase.
