Road Glide windshield gasket
I've been to the dealer 3 times because the gasket falls down from the edge of the windshield. Their fix is some rtv silicone and this time they told me that is the best it is gonna get. $20K on a new bike and that's their fix, any suggestions on a permanent fix?
However, if you work you way from the center screw outward toward the two ends, tightening each screw just a little bit more each time, and just keep pressing the gasket fully up into place as you go, then it seems to work okay.
Did for me anyway and twice too. Went from stock to KW 16" and now onto WV 14" (it's the keeper too).
Edit to add - BTW, do you know how to keep the well-nuts from falling off inside the fairing? ...or the easiest way to retreive one if it does? Shout out if you don't yet.
I think the black one's a new Kuri part. IIRC, the word is that they don't fit well but some folks have also said they fit "okay". Seems a lot like the gasket deal... may take a little "persuasion".
ETA - Paul Yaffe has a lighted one in black... http://www.baggernation.com/products-lights.htm
I ended up gluing the trim in place with the black RTV and taped the trim tight until it dried. It has been in place now for 30K+ miles.
