Mounting the wheel chock in the trailer
First off, iknow i should ride it not trailer it, but we always take a trip to Florida in mid dec . and riding out of Indiana at that time of year would suck!!!
So that beaing said, I just bought an enclosed trailer to haul bikes in. i have a couple of the HF chocks already and cant see spending more money to buy removable chock. Thats where the problem is, i want to make these chocks removable. My thought is that the chocks have a small amount of preasure against them, just mainly downward and a little forward??? I think that a threaded insert in the wood floor at all 4 mounting holes would be pleanty to hold the chocks in place, then attach the chock with a thumb screw for easy removal.
Soooo, what are your thought and concerns on this idea???
Here is a link to inserts on ebay so you get an idea what im talking about.
http://cgi.ebay.com/50-3-8-16-Flange...item5633b653d3
VR
Why not run some larger angle iron across to use as a stop for the front of the chock, and then use it unsecured, or maybe your wingnut idea? Just be sure to have straps on all 4 corners of the bike. If you have the HF chock I'm thinking of, I've put it in the bed of my truck on multiple occasions without bolting it to anything and it's been fine.
In my experience the bike won't be really secure unless you have some preload on the front forks, and to do that you will be applying forward pressure to the chock, you've gotta secure it in the forward direction somehow.
Greetings from South Carolina bambamblazer
I would not trust putting inserts into the wood for securing my bike, this will weaken your ability in your floor for securing your wheel chock.
I would have a metal brace mounted under the trailer and use all thread rods with avaitation nuts to secure your mount.
I have just had this done to my trailer and as soon as I can I will post pictures but I do not wish to have my wheel chock removable but it could be.
Tom
Tom
I'm a cabinet maker/contractor, so I have a fair bit of experience with wood. I also ride dirt bikes which means I have to trailer a bike on a regular basis (at least twice a month). Granted, dirt bikes are not as heavy as a road bike but the concept is the same.
The inserts you are looking at will work for the first handful of uses but after that they will start to come loose. Really though, you don't need much to hold a chock in place, it mostly downward and a little forward force. If you want a quick fix and you really only trailer the bike once a year or less, the inserts you are looking at would probably work provided you check them thoroughly each time you use them. If not, I would probably google "removable wheel chock" as there are some better options out there. And as far as the integrity of the wood, those insert won't effect it one bit. I'll bet if you look there are knots in the wood bigger than the insert you are going to use.
Nate
Nate
DO NOT DO THAT. I just trailered my bike to North Carolina in June. You would not believe the force that is put on those straps. Imagine someone in your trailer rocking your bike back and forth for hours and hours. We stopped for gas and checked the bikes and mine was on its side. Small damage (landed on suitcase) just pissed me off. I think what happened is I ratcheted the straps and not enough strap went around the shaft before it was tight to the block of wood under the frame. So thats all I can assume is that it just unwound from the spool(shaft) and bam , shes on the trailer.
That was a weak point and an anchor will be too. Carriage bolt through the chock and trailer and use nylon nuts. ITS YOUR BIKE.
