Which AIM VP Clutch
I would use the stock spring and 84T or if you want to save some money and see if it works for you, get the -98A 330lb spring and replace the SE spring with it. The -98A spring is less pull than the SE, but plenty enough to handle a 103" engine. The -98A spring is only about $30 and the VPC will run you about $300.
I would also agree with dawg to the extent that a simple spring change will offer less effort. The Harley habit has been to install a much stronger spring than is needed for the average riding public. They would rather have a heavy spring to prevent slippage complaints from people that ride them like they rented them, but most people don't.
The real positive for the VPC is that it can be installed through the derby cover in around 15-minutes with no loss of oil.
I guess the best of both worlds is to keep the strong spring and go with a VPC, but dawg makes a good point on the cost issue. $30 for a spring vs. $300 for the VPC is no small consideration.
I have plenty of friends on 96" bikes with the soft spring and have no issues with slippage in the mountains, but then again....they are box stock with no engine work. I suppose it is possible for Justin to go with the softer spring and just not "use all he has", or go with the VPC to solve both issues.
Just because he has hand issues should not keep him from playing with all the motor he has and it looks like his only way around that is the VPC if he is uncomfortable with his clutch pull. I am stepping out on a limb and saying the 70 would work and give him the full benefit of the least clutch pull. I ride a 1200 pound trike (Stage II TC-88), a wife, her baggage and a fully loaded trailer with a 70 over an SE spring and have never noticed any slippage.in the Rockies or anyplace else.
Justin...I just saw your post concerning the spring you have in there now. If you have the stock spring in there now and still have issues, the 83/84 will offer around a 20% reduction where the 70 will offer a 40% reduction. I'd say that since you have no slipping issues now....go with the 70. At higher RPM any of the VPC's will lock the clutch up tighter than the spring anyway.
